Jevon Posted May 23, 2007 Share Posted May 23, 2007 I am having a problem with my transmission for about a week now. I have a 1993 SC 300 with 134,000 miles and everytime I get on the freeway, which is everyday to go to work, and I get up around 50-60 mph the transmission shifts as if I just pressed the overdrive switch and the RPM will go from about 2500 up to 4000 and the transmission will stay in that the condition untile the car is turned off. I have no problem accelerating however when I do the RPM goes into the 5000-6000 range. I took it to get a transmission filter change and flush, and the tech said that the transmission was good. Next step was I had the Throttle Position Sensor changed and the cable from the transmission to the sensor adjusted that didnt help either. It just seems like when the transmission changes like that it will not go back to normal( meaning when the overdrive is on) unless I turn the car off and let it sit for a while. Also when it switches like that, I tried pressing the overdrive switch on and off and it is like the button does nothing at all to return the car back to the normal state( over drive on). Please someone help!!!!! Quote Link to comment Share on other sites More sharing options...
termin8or Posted May 31, 2007 Share Posted May 31, 2007 I had a KIA where the trans downshifted into 2nd gear and stayed there. That was a default when the computer doesn't detect what it thinks it should be seeing from a sensor. In the case of my KIA the shop replaced what was called the turbo speed sensor on the trans. There was an input and an output sensor. Not certain if this helps but I thought that I would offer it up. Quote Link to comment Share on other sites More sharing options...
