Just bought 94 es 300 with 163 k-----seems to be a fine car but the airbag warning light never goes out. Is there anything I can check before taking it to a lexus dealer and waiting for an astronomical repair bill? :rolleyes:
there is a way to check it
it involves opening the diagnostic cover over the engine
taking 2 wires and running them by the batteryback to the cover to connect to 2 pins in it
then turngin the key and grounding them back and fourth in a timed sequence a few times
this gives you the code by flashing the abs light in the car
so you need to contort with a mirror to look at the code
them find the code and it will reset the memory
unless the problem still exists
basically the srs light wil stay on until checked y a dealer if the problem is intermittent
if you realy wan tto do this i can post eh pins you have to short
but it is a pain in the !Removed!
and not for a diy
basically if you have less than 5 types of pliers your probably still diy
skp
Thanks for your response-----before I ask you for the exact procedure, what are the chances that resetting the code would solve the proble? There is no indication that this car has been hit in the front. Would things like changing the battery cause the light to need resetting?
changing the battery shouldn't but the system does have a back up power supply
you
could also disconnect the battery for about an hour which also might clear it
