allen2030 Posted May 13, 2007 Share Posted May 13, 2007 Thanks to a member's help, I was able to find the bolts/holes for draining oil, transmission fluid and the coolant as I did the 60,000 fluid change. Now I have no idea where the TRANSFER CASE is. Would anyone send me a picture/ link or description on where to find it? I have Toyotas, VWs, a Mercedes (pretty bad), Volvo (not so great) and now RX 300. I have never been so challenged before by locating the essential service portals.... Thanks... Quote Link to comment Share on other sites More sharing options...
wwest Posted May 14, 2007 Share Posted May 14, 2007 Thanks to a member's help, I was able to find the bolts/holes for draining oil, transmission fluid and the coolant as I did the 60,000 fluid change. Now I have no idea where the TRANSFER CASE is. Would anyone send me a picture/ link or description on where to find it? I have Toyotas, VWs, a Mercedes (pretty bad), Volvo (not so great) and now RX 300. I have never been so challenged before by locating the essential service portals.... Thanks... One end of the rear driveline/shaft goes to the rear diff'l and the other goes to the "transfer case", more appropreately referred to in the RX as the PTO, Power Take Off. Quote Link to comment Share on other sites More sharing options...
cuda Posted May 14, 2007 Share Posted May 14, 2007 http://www.clublexus.com/forums/showthread.php?t=220061 Quote Link to comment Share on other sites More sharing options...
allen2030 Posted May 15, 2007 Author Share Posted May 15, 2007 http://www.clublexus.com/forums/showthread.php?t=220061 THANK YOU and much appreciation. If you were in Austin, TX, I would have taken you out to lunch... Quote Link to comment Share on other sites More sharing options...
