bradgoali Posted August 26, 2003 Share Posted August 26, 2003 i was wondering if any one has removed the door panels on there rx and could give me some advice my last car was a mazda and only had 2 screws then the pins, so i was wondering if the lexus was also that easy. any help is greatly appreciated. Quote Link to comment Share on other sites More sharing options...
jeremyp Posted August 29, 2003 Share Posted August 29, 2003 Here are the screw/fastener locations (got this pic from another site) Quote Link to comment Share on other sites More sharing options...
jeremyp Posted August 29, 2003 Share Posted August 29, 2003 The small pop pins on the outer edge just need to be pushed in and then lightly pryed out. The handle bezel has a cover over a screw, just pry the cover open with a small screwdriver and take out the screw. and then use a small flat head screwdriver to pry it off the handle (see photo attached). The window/lock switch panel is a tough one. You need to pry on the top edge carefully with a large flat screwdriver or preferably a door panel tool (you can get 'em at auto parts stores). Once you get that off, then take out the screw on the inside of the hole left by removing the panel. Now take out the screw below the armrest and then pry the panel from the door from the bottom and don't forget to disconnect the wire to the light on the bottom of the door once you get it open. Hope this helps ya. Just be careful your first time. The second time is very easy. JP Quote Link to comment Share on other sites More sharing options...
bradgoali Posted August 30, 2003 Author Share Posted August 30, 2003 thank you very much for your help i am going to give it a try the next time the weather is nice. Quote Link to comment Share on other sites More sharing options...
