Missing The Point?
LEXONDUBZ
I bought this 1991 ls400 for cheap because the starter was out. i replaced the starter and she ran fine... except for a leaking water connection tube. <_< I changed the gaskets and after putting everything back together, now the engine has a terrible miss! i checked everything from the injectors to sensors to ... well everything! the numbers 1 and 7 cylinders seem to not be working... i unplugged the injector plugs and the engine still runs the same. i swapped plug wires, injectors, plugs and it still runs the same! has anyone run into this problem also ? any ideas? am i missing something here or overlooking something? HELP PLEASE! :cries:
1 & 7 are side-by-side at the distributor cap, so I'd inspect the cap and rotor closely.
I'VE REPLACED THE CAP AND ROTOR ALREADY AND STILL NOTHING FROM THOSE TWO CYLINDERS...
DUBZ:
Caps lock off & a compression check on those two cylinders would work wonders. :whistles:
