Error Code 0150 And 0153
Hello,
It's happened@ 242,000
I got check engine light. Autozone discovered 0150 and 0153.
Please guide me which O2 Sensoe needs to replace.(Bank 2 Sensor 1)?
Where to buy?
Is it easy to replace or take it to mechanic?
Thanks,
I went to Orailly this morning, same code. and it's reset.
no more light.
also went to toyota dealer and bought 2 sensor incase the light show up.
reason bought two, because my mechanic told me to replace both.
but i don't understand, the lexus manual says (front)between radiator and manifold is
Bank 1 Sensor 1 where toyota main tech foreman told me that is Bank 2 Sensor 1.
Please confirm.
I will wait till light shows up again. if not i will return parts.
any idea, how long it will take to show up that CE light.
Thanks,
Toysrme,
Thank you very much.
should i replace now or wait till light shows up.
car has 242,000 and this is first time i am going replace.
I bought from toyota $104 a peice, both are same.
Thanks,
It was not hard to replace. I started with front to learn connector and replace the rear from top by standing driverside.
both are new. Another 100,000 easy....
I did bought special tools from Oreilly for $10
Thanks for everyone's input. I see improvement on Engine.
