Ls400 92 Speedometer Dial Light
zenlama
The speedometer dial arm on my 92 LS400 is patialy blacked out. Only about a third from center is lit. I was wondering if just this part could be replaced. Does it mean its going to die completely. Do you have to change the whole instument cluster to fix this? If the later is the case, I will live with it as I use a Garmin navigation system that actually has a good speedometer (only visible in map mode, not when navigating). Thanks, Bob
Read the last few posts on Page 11 of the sticky at the top of the page. The sticky is about the various instrument panel problems, with the fading needles being just one of the problems.
