I've blown the 15 amp fuse for the air conditioning and every time I put in a new fuse it blows it as soon as I put it in! The fuse is located in # 36 of the fuse box under the hood and is labeled the ECU-B, antilock brakes, traction control and air condotioning. I know it means I have a short somewhere...but how do I locate it?? Thanks in advance for any help!!
unplug the harness on the compressor and test it with a meter at the fuse plug not by burning fuses.
Thank you!! I'll try that!!
