mckellyb Posted August 25, 2003 Share Posted August 25, 2003 I know the windows/sunroof open if you hold the remote's 'unlock' button down, but aren't they also able to be closed by holding down the 'lock' button? I'm going in to pick up three little screws which have fallen out/been misplaced by the previous owner's service dept., and was considering taking the RX in to have this changed, if it can be, *and* have he doors set to one push = unlock all. Is there a good way to approach this, and who would I take it up with??? I've *never* had a dealer who was worth a damn, so the friendliness there, Beaverton, OR Lexus, catches me by surprise. Thanks! Quote Link to comment Share on other sites More sharing options...
RX300-BV Posted August 25, 2003 Share Posted August 25, 2003 I don't believe you can use the lock button to auto close the windows and sunroof. However, you can insert the key into the door lock and turn and hold in the lock position to auto close the windows and sunroof. As for changing the alarm to one button unlock all, tell your service adviser you want to change one of your CBEST settings. Here's additional FYI for all RX300 owners. What is C-Best and the C-Best settings for the RX 300? C-BEST system stands for "Customized Body Electronics" System. It is a system that allows customization through the dealer's handheld tester with C-BEST cartridge installed. The variables that are available for customization are as follows: Wireless Door Lock Remote Control Wireless operation Yes* / No Door ajar warning beeper Yes* / No Automatic Lock operation 30s* / 60s All door unlock (one press) On / Off* All door unlock (2 presses) On* / Off Panic Alert Operation On* / Off Door Lock Control (Key) All door unlock (key turn 1x) On / Off* All door unlock (key turn 2x) On* / Off Illuminated Entry Light Illum time 7.5s / 15s* / 30s Interior lights illum on key unlock On* / Off Automatic Lights Sensitivity -40%/-20%/0%*/+20%/+40% Control logic switchover New(type 1)* / Prev (type 2) Theft deterrent Passive arming On / Off* Vehicle horn and security horn On* / Off Entry delay time switch 0s / 14s* / 30s Power window system Key-linked open On* / Off Key-linked close On* / Off *denotes default factory setting It takes the dealer about 10-15 minutes to change any or all items. 1. Connect meter to DLC3 port 2. Turn on ignition 3. Go to "Customize" menu to make selections. Most dealers do not charge for this service. Quote Link to comment Share on other sites More sharing options...
