Rufus Posted March 20, 2007 Share Posted March 20, 2007 I own a 2004 IS 300 with a manual transmission, which I purchased new in August 2004; as of today the car has approximately 20,000 miles on the clock. Since the winter of 2005 I have noticed that when the outside temperature is freezing or below the transmission is stiff and emits a grinding/rasping sound when I shift, either up or down, into second gear; shifting into other gears is fine. The dealer doesn't seem to know what is causing this, other than "it's cold out". What puzzles me is that this only happens when shifting into second and both the stiffnes and noise are not present when the temperature rises above freezing. Has anyone else come across this problem, should I be concerned, and what can I do about it? Quote Link to comment Share on other sites More sharing options...
Scott M Posted March 21, 2007 Share Posted March 21, 2007 I own a 2004 IS 300 with a manual transmission, which I purchased new in August 2004; as of today the car has approximately 20,000 miles on the clock. Since the winter of 2005 I have noticed that when the outside temperature is freezing or below the transmission is stiff and emits a grinding/rasping sound when I shift, either up or down, into second gear; shifting into other gears is fine. The dealer doesn't seem to know what is causing this, other than "it's cold out". What puzzles me is that this only happens when shifting into second and both the stiffnes and noise are not present when the temperature rises above freezing. Has anyone else come across this problem, should I be concerned, and what can I do about it? Nothing more than a guess from a guy who knows nothing about what he's talking about.... Sounds like moisture in the Clutch Hydraulics. If that's the cause, it would only show itself when the temp is below freezing. I had issues with the hydraulics once in a different car. The symptoms were stiffness and difficulty shifting to and from 1st gear only. Other gears were easy. Quote Link to comment Share on other sites More sharing options...
djspawn00 Posted March 22, 2007 Share Posted March 22, 2007 i think your powertrain is still underwarranty... if that helps any... Quote Link to comment Share on other sites More sharing options...
Parking17 Posted March 22, 2007 Share Posted March 22, 2007 Try this: When shifting to second, put the clutch all the way in, hold the stick in second and slowly let the clutch out. It should slide into gear. I have to do this for "reverse" when it's cold. It may be a frozen dog tooth gear not engaging with the speed of the engine, particularly second gear until it gets to operating temperature. Cut and paste link below to understand what I mean. As stated in the previous post, you should still be under warranty. Don't let them shove you off. Hope this helps. - Good luck. http://en.wikipedia.org/wiki/Manual_transm...d_transmissions Quote Link to comment Share on other sites More sharing options...
