Humming Noise While Pressing On Gas Pedal
Hey guys I have been noticing a low humming sound and it is felt on the gas pedal while im driving but I have no idea what it could be. Any advice, help would be great
This may not be the best answer but I'd say get under the car and look for any loose heat sheilds... that could make noise... but the feeling I'm not sure about maybe engine or tranny mounts? Is it only when the car is in motion? also check your tires for balancing and uneven wear.
Yes the noise is only when the car is in motion and is it common for it to be the heat shield around the exhaust manifold?
The humming noise is only noticable when the car reaches higher rpms right before the tranny shifts and after the tranny has shifted out of 4th the noise starts slowly gets louder when reaching higher speeds.
