3rd timer Posted March 12, 2007 Posted March 12, 2007 I drive a 2006 IS 250 AWD that I love BUT 4 times the VSC light (and engine/warning light too) comes on when starting up AND STAYS ON. It doesn't happen when driving, but when starting up next day after a hot ride home. I am now scheduled for an overnight service, but if someone knows the solution, or even if this problem is common, I'd like to know. Thanks, X3r
bartkat Posted March 12, 2007 Posted March 12, 2007 It's throwing a code. You should have them read to code and correct the problem.
3rd timer Posted March 12, 2007 Author Posted March 12, 2007 It's throwing a code. You should have them read to code and correct the problem. It's throwing a code. You should have them read to code and correct the problem.
bartkat Posted March 13, 2007 Posted March 13, 2007 It's throwing a code. You should have them read to code and correct the problem. It's throwing a code. You should have them read to code and correct the problem. Huh?
is_in_red Posted March 17, 2007 Posted March 17, 2007 I drive a 2006 IS 250 AWD that I love BUT 4 times the VSC light (and engine/warning light too) comes on when starting up AND STAYS ON. It doesn't happen when driving, but when starting up next day after a hot ride home. I am now scheduled for an overnight service, but if someone knows the solution, or even if this problem is common, I'd like to know. Thanks, X3r I had that happen when I took the car out during a blizzard (Valentines Day 2007) to have some fun. I probably confused the system by activating the VSC too frequently. The lights you describe came on. After letting it sit for an hour it reset.
