Has anyone else had this problem? I used to be able to hold down the pwr door button and the rear door would open. Does anyone know if this can be disabled by any options on the NAV screen or is it just a problem and I have to take it in :(....
There is a button inside the glove box door (left side iI think) that, if pushed in, can disable some functions of the power door.
Check inside the glove box. There is an on/off switch for the power rear door.
Tom
Tom
And, there are also some personalization settings the monkey with how the door works such as can you open it without unlocking all the other doors first... so if you just had any of that changed, you may be experiencing (what they call in the Artificial Intelligence world) emergant behavior.
the most common reason for it to have stopped working is:
the door closed on something and blocked it, thereby forcing it to reopen. If this happens it has to be reset. Reset it by opening the door fully by hand, and then closing it. lol
