elbee Posted February 26, 2007 Share Posted February 26, 2007 Change trans. oil last week I put too much oil cause it's hard to see the oil level on the stick, now oil is seeping thru the pan gasket. Do I need to take the pan out and reseal. Seems like there is no gasket but the sealant. I tried tightening the bolts around the pan and drain some oil but still leaking :cries: :cries: Quote Link to comment Share on other sites More sharing options...
SKperformance Posted February 26, 2007 Share Posted February 26, 2007 You do need to remove it and reseal the edges. Clean the old one away and refill with new fluid as well as clean the mesh and magnets while you are in there. Quote Link to comment Share on other sites More sharing options...
