Sign in to follow this
buckyes300
High-mounted Brake Light
I have a 1998 ES300, need to replace the bulb for the high mounted brake light. My Haynes Camry manual shows release clips acessable through the trunk. Can't find the clips (tabs) in my trunk. My car does have a center mounted rear speaker in the housing assembly. Thought the speaker grill may pull off easily to get to the bulb, but no luck here.
I'm sure I'm missing something obvious, what's the trick?
Thanks in advance.
buckyes300
Share this post
Link to post
You have to pop off the subwoofer cover and the 3rd brake light is connected to it. There is 2 clips on the cover, there are on the left and right opposite the brake light.
Share this post
Link to post
Loading...
