Vetter Posted February 6, 2007 Share Posted February 6, 2007 The original radiator cap on my 1994 ES300 has gained a divit in the rubber seal where the overflow tube joins the alloy housing the cap mates with (the rubber is degrading). The top of my cap has 1.0 embossed on one of the wings. I take this means 1.0 bar, or the 83-113 kPA (.85 - 1.15 kg/cm2) that the service guide claims is the normal range for the pressure. I'd like to replace the cap. Trouble is, the parts that I can find are 1.1 bar. I don't feel the small PSI increase will affect much, but I would like to know if 1.0 caps are still available (what part number)? Are there cold climate and warm climate models? I can't see in the ordering system where the original part was superceeded. Thanks. Quote Link to comment Share on other sites More sharing options...
Vetter Posted February 6, 2007 Author Share Posted February 6, 2007 Part 16401-62090 is the correct CAP - a 1.0 bar. The pictures shown on the Web, and the one shipped to me must have been for a different model, or later year. Quote Link to comment Share on other sites More sharing options...
Toysrme Posted February 6, 2007 Share Posted February 6, 2007 The higher the pressure, the longer it takes the coolant to boil. You're perfectly fine. 1.4-1.6bar would be a common upgrade for a 1 bar system. Quote Link to comment Share on other sites More sharing options...
