gdiz Posted January 30, 2007 Share Posted January 30, 2007 I'm having difficulty automatically connecting my Cingular Raxr 3 to the navigation system. I can only get it to connect by searching both devices at the same time. Any Ideas? Quote Link to comment Share on other sites More sharing options...
ADoll Posted January 30, 2007 Share Posted January 30, 2007 Make sure that on your phone you have it set under settings, connections, bluetooth that the bluetooth is powered on all the time. If it is not then the phone will only connect when you select Find Me. Also make sure that you set the Handsfree as trusted. Quote Link to comment Share on other sites More sharing options...
gdiz Posted February 1, 2007 Author Share Posted February 1, 2007 Make sure that on your phone you have it set under settings, connections, bluetooth that the bluetooth is powered on all the time. If it is not then the phone will only connect when you select Find Me. Also make sure that you set the Handsfree as trusted. How do I set the handsfree as trusted? I entered the passkey into the phone. Thanks Quote Link to comment Share on other sites More sharing options...
gordonw Posted February 1, 2007 Share Posted February 1, 2007 http://lexusbluetooth.letstalk.com/brands/...f/14_05Navi.pdf Quote Link to comment Share on other sites More sharing options...
