Power Mirrors Help! Don't Work
MikeMiel
The power mirrors do not work on my sc400. The thing is is that neither one doesn't work, so if both don't work, it needs to be an electrical thing, not something in the gears or locked up somewhere. I checked the fuse, their fine. Is there anything else I should check? Thank You in advance.
Check the plug which is underneath the mirror control panel in the driver's side arm rest. It's pretty easy to pop out...just a small screwdriver will do the trick. Once the panel is popped out, look at the plug.
if that doesnt do it, it is your mirror ecu which is faulty. they go bad all the time. i have one for 40 shipped to your door.
email is gazi.ali@gmail.com
