Vsc/abs/buzz Noise On
I'm going to guess you are hearing the VSC warning chime. Since the ABS light is on as well, I would suspect a bad wheel speed sensor/wiring. You need a scantool to monitor the individual wheel speeds and point you in the right direction as to the cause.
