Removing Radio / Climate Control Stack 1995 Es300
Kwaj
Does anyone have the knowledge on how to remove the front cover ~ panel on the radio and climate control area of a 1995 ES300?
I'm looking to change the bulbs.
Thanks in advance.
Regards,
Kwaj
Remove the radio/ac unit and remove the 2 side brackets, There are small brass screws on both sides of units, Remove and use a screwdriver to unclip the faceplate. Good Luck....
The most difficult part is removing the ac vents above the radio,
Thanks in advance.
Regards,
Kwaj
I have a 97 ES300 and I need to replace all of the bulbs except for the lcd. What part number are those bulbs?
