slinger2424 Posted December 6, 2006 Posted December 6, 2006 I am looking at a few Free Air subs to upgrade my stock 10" in the rear deck. Anyone done this with sucess? Sound good? Waste of time? Will I need to upgrade the amp or can I run the stock one? Here are some options... Kicker Comp 05C104 $90 10" 4-ohm Component Subwoofer Polymineral cone • foam surround • marine-ready • free-air use • 50-150W RMS power range • 30-500 Hz frequency response Infinity Perfect 10.1 $150 10" 4-ohm Component Subwoofer Aluminum cone • high-roll rubber surround • 75-350W RMS power range • 18-200 Hz frequency response Infinity Kappa 102.7W $180 10" Switchable 1 or 4-ohm Component Sub Selectable 1- or 4-ohm impedance • woven glass fiber cone • rubber surround • neodymium magnet • 50-350W RMS power range • 25-400 Hz frequency response Tell me what you all think??
BrabusCClass Posted December 6, 2006 Posted December 6, 2006 I am looking at a few Free Air subs to upgrade my stock 10" in the rear deck. Anyone done this with sucess? Sound good? Waste of time? Will I need to upgrade the amp or can I run the stock one? Here are some options... Kicker Comp 05C104 $90 10" 4-ohm Component Subwoofer Polymineral cone • foam surround • marine-ready • free-air use • 50-150W RMS power range • 30-500 Hz frequency response Infinity Perfect 10.1 $150 10" 4-ohm Component Subwoofer Aluminum cone • high-roll rubber surround • 75-350W RMS power range • 18-200 Hz frequency response Infinity Kappa 102.7W $180 10" Switchable 1 or 4-ohm Component Sub Selectable 1- or 4-ohm impedance • woven glass fiber cone • rubber surround • neodymium magnet • 50-350W RMS power range • 25-400 Hz frequency response Tell me what you all think?? My suggestion is to def get a nice strong amp to power it. I am not sure what a freeair will sound but Im guessing it should sound better than stock. I was going to make a custom bandpass box and remove the stock 10" and port it through there. As per what subs thats your choice. Try to find people who have that specific sub and listen to it. I like the sound of JL Audio, Orion, and some Fosgate and Kicker. You should run it at 2ohms bridged to get the most power out of your amp. Also like I stated before get a really strong amp because you can always turn down the gain if its too strong. Weak amps or amps that seem to match up in watts usually are too weak and when you push your amp it shuts off because it overheats. Its lame and you will not be happy. Good luck on your quest for better bass.
SKperformance Posted December 7, 2006 Posted December 7, 2006 Get dynomat to insulate your trunk to seal it better.
