chargerucd Posted December 4, 2006 Posted December 4, 2006 Hey guys, i finally save a little bit of $$ and i'm looking for a whilte line sway bar lit, do you guys know where i can get frnt and rear kit maybe with poly bushings. also where to get a strut bar. thanks for the help
chargerucd Posted December 4, 2006 Author Posted December 4, 2006 FYI Forgot to mention it is a 1996 es300!! thanks for the help Hey guys, i finally save a little bit of $$ and i'm looking for a whilte line sway bar lit, do you guys know where i can get frnt and rear kit maybe with poly bushings. also where to get a strut bar. thanks for the help
chargerucd Posted December 5, 2006 Author Posted December 5, 2006 Just to mention it, I looked at the www.globalperformanceparts.com website and for the year 1996 they only list SC300 and SC400, so do the parts for the SC300 also fit ES300? Just wondering
andrecat112 Posted December 5, 2006 Posted December 5, 2006 look up for a 1996 toyota camry, you should see corresponding sway bars
chargerucd Posted December 6, 2006 Author Posted December 6, 2006 Hello, I just looked for some for the camry and they only list the rear. do they not list the front? I supposed that for best results, front and read must be changed. just wondering.
Toysrme Posted December 6, 2006 Posted December 6, 2006 We do not have front sway bars. Rear sway bars is what you want to upgrade on a FWD car. Noone has made RSB's for the gen 3 Camry platform (92-96) because they're big enough already. Toyota downgraded their size in 1997.
grace Posted January 31, 2007 Posted January 31, 2007 Be sure the change the sway bar bushings while you're at it. I changed the sway bars and found the ride still rough.
SupraMan Posted February 1, 2007 Posted February 1, 2007 Be sure the change the sway bar bushings while you're at it. I changed the sway bars and found the ride still rough. If you buy a sway bar, the bushings and lube come with it. I got my '96 ES300 upgraded with the Whiteline bar through Global parts; definate improvement in lean angle and suspension response. Dead stock suspension otherwise - I did the whole job though and also added new end links with the bar addition. Highly recommended mod!
