Whiteline Sway Bars,
FYI
Forgot to mention it is a 1996 es300!!
thanks for the help
Hey guys,
i finally save a little bit of $$ and i'm looking for a whilte line sway bar lit, do you guys know where i can get frnt and rear kit maybe with poly bushings. also where to get a strut bar.
thanks for the help
  • 1 month later...
Be sure the change the sway bar bushings while you're at it. I changed the sway bars and found the ride still rough.
If you buy a sway bar, the bushings and lube come with it. I got my '96 ES300 upgraded with the Whiteline bar through Global parts; definate improvement in lean angle and suspension response. Dead stock suspension otherwise - I did the whole job though and also added new end links with the bar addition. Highly recommended mod!
:cheers:
