Questions On Buying Rims For Is350
omad
Im planning on buying 19" wheels for my IS. The tires i have now is 225/35/18.
the option for tires are 225/35/19 front and back.
or
235/35/19 front/back.
will 235's fit okay in the front, or will it grind? anyone have expierence w/ this?
I would also like to have the rear wheels 245's.. im not sure if it will work.
and has anyone had any problems w/ the tire sensors w/ after market wheels?
thanks
-omad
We are running 20x9 with 245/25-20 in the front without rubbing, Trick is getting the right wheels with the correct fitment for the front. Be sure to check brake clearance and suspension clearance and you will be ok.
BTW, we run a 20x10.5 in the rear with 275/25-20 without problems.
It is all about the fit...
Good Luck with your wheel hunting...
post-34003-1171307921_thumb.jpgpost-34003-1171307943_thumb.jpgSorry about the lateness of this post, wasn't paying attenetion....oh, huh, did you say something, oh ok... sorry, are three pictures of the car with the 20"s :unsure:
Very nice wheels. Wondering how they look from behind? Do they hang out at all or do they look just right and tucked in? Any recommendations on strut/spring kits?
