taba82 Posted November 22, 2006 Posted November 22, 2006 Has anyone found the "hack" for the v6 DVD (like the one in v5 on the Volume screen) which allows you to override the system so you can enter destinations while the car is in motion?
navguy Posted December 1, 2006 Posted December 1, 2006 Has anyone found the "hack" for the v6 DVD (like the one in v5 on the Volume screen) which allows you to override the system so you can enter destinations while the car is in motion? The hidden menu has been eliminated.
PIONEERSUBY Posted December 4, 2006 Posted December 4, 2006 Has anyone found the "hack" for the v6 DVD (like the one in v5 on the Volume screen) which allows you to override the system so you can enter destinations while the car is in motion? The hidden menu has been eliminated. you make a copy from your own original v5 and v6 dvd for your own use. using dual layer burner copy v5 firmware at beginning then v6 map data . so overide will still be there but with 2006 data. i do not have any such copies for sale. it is against toyota coyright to sell copies. this is only recomended for your own use from original dvd map discs that came with the vehicle or purchased from a toyota dealer. also it is not recomended the driver use this modification while vehicle moving. only the passenger can use it safely. i hope there were enough warings in this post.
JW 03 ES 300 Posted December 26, 2006 Posted December 26, 2006 Has anyone found the "hack" for the v6 DVD (like the one in v5 on the Volume screen) which allows you to override the system so you can enter destinations while the car is in motion? The hidden menu has been eliminated. you make a copy from your own original v5 and v6 dvd for your own use. using dual layer burner copy v5 firmware at beginning then v6 map data . so overide will still be there but with 2006 data. i do not have any such copies for sale. it is against toyota coyright to sell copies. this is only recomended for your own use from original dvd map discs that came with the vehicle or purchased from a toyota dealer. also it is not recomended the driver use this modification while vehicle moving. only the passenger can use it safely. i hope there were enough warings in this post. Ive tried to backup my dvd but i cannot get my 03 es to read the disk. I used a memorex dvd+r dl disk...what dvd media are u using. I'd like to know b4 i make another 5 dollar coaster. Thanks!
PIONEERSUBY Posted December 26, 2006 Posted December 26, 2006 Has anyone found the "hack" for the v6 DVD (like the one in v5 on the Volume screen) which allows you to override the system so you can enter destinations while the car is in motion? The hidden menu has been eliminated. you make a copy from your own original v5 and v6 dvd for your own use. using dual layer burner copy v5 firmware at beginning then v6 map data . so overide will still be there but with 2006 data. i do not have any such copies for sale. it is against toyota coyright to sell copies. this is only recomended for your own use from original dvd map discs that came with the vehicle or purchased from a toyota dealer. also it is not recomended the driver use this modification while vehicle moving. only the passenger can use it safely. i hope there were enough warings in this post. Ive tried to backup my dvd but i cannot get my 03 es to read the disk. I used a memorex dvd+r dl disk...what dvd media are u using. I'd like to know b4 i make another 5 dollar coaster. Thanks! most successful copies were made on verbatim dl media/ 2.4 x. lots of coasters on memorex. also the setting has to be book type not setting the for movie copies.
JW 03 ES 300 Posted December 26, 2006 Posted December 26, 2006 Has anyone found the "hack" for the v6 DVD (like the one in v5 on the Volume screen) which allows you to override the system so you can enter destinations while the car is in motion? The hidden menu has been eliminated. you make a copy from your own original v5 and v6 dvd for your own use. using dual layer burner copy v5 firmware at beginning then v6 map data . so overide will still be there but with 2006 data. i do not have any such copies for sale. it is against toyota coyright to sell copies. this is only recomended for your own use from original dvd map discs that came with the vehicle or purchased from a toyota dealer. also it is not recomended the driver use this modification while vehicle moving. only the passenger can use it safely. i hope there were enough warings in this post. Ive tried to backup my dvd but i cannot get my 03 es to read the disk. I used a memorex dvd+r dl disk...what dvd media are u using. I'd like to know b4 i make another 5 dollar coaster. Thanks! most successful copies were made on verbatim dl media/ 2.4 x. lots of coasters on memorex. also the setting has to be book type not setting the for movie copies. thanks! gonna head to fry's to pick up some more coasters...i mean dvds
JW 03 ES 300 Posted December 27, 2006 Posted December 27, 2006 Has anyone found the "hack" for the v6 DVD (like the one in v5 on the Volume screen) which allows you to override the system so you can enter destinations while the car is in motion? The hidden menu has been eliminated. you make a copy from your own original v5 and v6 dvd for your own use. using dual layer burner copy v5 firmware at beginning then v6 map data . so overide will still be there but with 2006 data. i do not have any such copies for sale. it is against toyota coyright to sell copies. this is only recomended for your own use from original dvd map discs that came with the vehicle or purchased from a toyota dealer. also it is not recomended the driver use this modification while vehicle moving. only the passenger can use it safely. i hope there were enough warings in this post. Ive tried to backup my dvd but i cannot get my 03 es to read the disk. I used a memorex dvd+r dl disk...what dvd media are u using. I'd like to know b4 i make another 5 dollar coaster. Thanks! most successful copies were made on verbatim dl media/ 2.4 x. lots of coasters on memorex. also the setting has to be book type not setting the for movie copies. thanks! gonna head to fry's to pick up some more coasters...i mean dvds hrmph! made another coaster. Guess another question would be what burning software are u using? im using nero.
