Rough Engine Revs
does the car miss at all? if not i suggest checking out the engine and trans mounts.
Nope. Doesn't miss. You're probably right on the money about the engine and tranny mounts though. I was just thinking about how I need to get in there and swap those out. I've read in past posts that the tranny mounts are not hard at all to do, but the engine ones take a little more patience. Have you done yours before?
yes i have!
start with the tranny mount. its easy and cheaper than the engine mounts. all you need are some socket wrenches and jack stands and a jack.
put the car on jackstands then jack the trans up then unbolt a few nuts and bolts and replace.
yes i have!
Soweet! I'll try and knock that out this weekend.
Thanks jzz
