jlim0930 Posted October 17, 2006 Share Posted October 17, 2006 I have checked my tire pressures 2 times just to make sure but the low tire pressure warning is not going away. Is there a way to reset it ? Quote Link to comment Share on other sites More sharing options...
Muwka Posted October 23, 2006 Share Posted October 23, 2006 I have checked my tire pressures 2 times just to make sure but the low tire pressure warning is not going away. Is there a way to reset it ? Your dealer should reset it for you for free. Quote Link to comment Share on other sites More sharing options...
motocopter Posted October 23, 2006 Share Posted October 23, 2006 This may seem crazy but try taking your tire pressures to zero and then refilling. We had a couple of issues with our OEM tires and the TPMS. In the end, mostly due to worn treads we replaced all four tires. But, earlier this year I had to plug one of the tires that still had a very slow leak in which about a month ago the TPMS alerted us. Even though we had all tires aired up, the light wouldn't go away. So, I ignored the warning as were getting ready to put on some new tires. Afterwards the warning had gone away. So, that makes me wonder if the transmitter needed to be cycled. Going to the dealer is inconvenient so it may be worth a try. Quote Link to comment Share on other sites More sharing options...
donbl Posted October 31, 2006 Share Posted October 31, 2006 This may seem crazy but try taking your tire pressures to zero and then refilling. Had a warning light at 5000 miles that would not go away. In the end, the only fix was replacement by dealer. Quote Link to comment Share on other sites More sharing options...
motocopter Posted November 1, 2006 Share Posted November 1, 2006 sort of stinks having to go to the dealer for pesky problems doesn't it? Quote Link to comment Share on other sites More sharing options...
Lexus Master Tech Posted November 7, 2006 Share Posted November 7, 2006 Try raising or lowering the tire pressure by at least 6 pounds per tire. Then set the tire pressure to your desired pressure. Do this with the ignition switch ON. That should fix your problem Quote Link to comment Share on other sites More sharing options...
