timspell Posted October 14, 2006 Posted October 14, 2006 WHAT ARE THE TORQUES FOR INSTALLING THE INTAKE MANIFOLD AND ALSO THE PLENIUM? I HAD TO CHANGE THE KNOCK SENSORS HARNESS.
mehullica Posted October 14, 2006 Posted October 14, 2006 Lower intake is 11 ft/lbs, the plenum, or upper intake is 32 ft/lbs
timspell Posted October 14, 2006 Author Posted October 14, 2006 HAVE YOU USED THESE VALUES 11 FT/LBS FOR THE LOWER MANIFOLD AND 32 FT/LBS FOR THE UPPER MANIFOLD? 32 FT/LBS SOUNDS HIGH FOR ALUMINUM
mehullica Posted October 14, 2006 Posted October 14, 2006 Yes I have. They are from the repair manual. I did some head gaskets a couple months ago and followed the specs.
timspell Posted October 14, 2006 Author Posted October 14, 2006 THANK YOU FOR YOUR HELP I WILL PUT MY INTAKE ON SUNDAY
JES Posted October 16, 2006 Posted October 16, 2006 WHAT ARE THE TORQUES FOR INSTALLING THE INTAKE MANIFOLD AND ALSO THE PLENIUM? I HAD TO CHANGE THE KNOCK SENSORS HARNESS. I have a P0330 and was curious how you determined it was the harness. Also would like to know what gaskets are required. Car is not going ino overdrive and from my research most people are replacing both know sensors and harness. Where do you get the parts? Thanks
snow-board Posted October 22, 2006 Posted October 22, 2006 WHAT ARE THE TORQUES FOR INSTALLING THE INTAKE MANIFOLD AND ALSO THE PLENIUM? I HAD TO CHANGE THE KNOCK SENSORS HARNESS. Can you tell me where you got the harness for the sensors?
timspell Posted October 28, 2006 Author Posted October 28, 2006 WHAT ARE THE TORQUES FOR INSTALLING THE INTAKE MANIFOLD AND ALSO THE PLENIUM? I HAD TO CHANGE THE KNOCK SENSORS HARNESS. Can you tell me where you got the harness for the sensors? i bought the harness at lexus lexus
JerryEarp Posted August 24, 2019 Posted August 24, 2019 You can get knock sensors with horness online for about 80 bucks pluss shipping.Go to AM auto parts.i purchased mine there.it beats paying 400 bucks at the dealer or part store.
