calbsc400 Posted October 13, 2006 Share Posted October 13, 2006 :) Got in the 95 SC400 this morning, turned the key, steering wheel started to adjust to driving position and then I lost all electrical power . I didn't check the headlights but the dome and all that are gone. Turn the key to the on position and nothing lights ups. What do you think happened? It was running great and I had no indications that something was wrong. I'm thinking there is a main circuit breaker or fuse or relay that has gone out. I have the manuals but to save me some time if anyone knows where these items are located please let me know. All other feedback is appreciated :D . Quote Link to comment Share on other sites More sharing options...
calbsc400 Posted October 14, 2006 Author Share Posted October 14, 2006 Initial testing indicates the starter relay has quit working. I've tested it to the best of my ability. Hooked up a power supply to the switch side and tested for continuity and voltage on the load side. No continuity or voltage on the load side. The reason I question my technique is my power supply only delivers in the milliamp range however I did test it on a different, known good auto relay, and it triggered the relay. I hate buying electrical parts without knowing for sure because if you get it wrong, there's no returns. Quote Link to comment Share on other sites More sharing options...
calbsc400 Posted October 14, 2006 Author Share Posted October 14, 2006 While waiting for a relay, I just thought I'd see what would happen if bypassed the starter relay. By the way, I do have some power back. The dome lights function and most likely the head lamps. As so as my key starts to enter the ingnition switch all power drops to nothing. An I mean "as soon as". I watched and it goes in 1/4" and the power is gone. It resets and comes right back on but I'm wondering now "would a short in the starter cause the relay to go bad?" Quote Link to comment Share on other sites More sharing options...
jbarhorst2 Posted October 14, 2006 Share Posted October 14, 2006 Maybe your lock cylinder is bad. When you turn the key to start the car, nearly all electrical functions are cut off so all the power goes into starting the car. If your lock is bad it could be cutting power to everything as soon as you put the key in. I'm not sure how you would test for that. Tom Quote Link to comment Share on other sites More sharing options...
calbsc400 Posted October 14, 2006 Author Share Posted October 14, 2006 After all this BS it looks like it is the battery. Not sure at this time but I've got it on the charger and after hour or so I'll give it a go. What makes me think its the battery now is that now that I have some power back I wanted to move the seat back to have a look at the lock cylinder solenoid. As soon as I pushed the button to move the seat back, all power dropped out. My battery is new and it shouldn't go dead overnight with just a dome light on though. I'll have to check into it. I'll keep you posted Quote Link to comment Share on other sites More sharing options...
calbsc400 Posted October 14, 2006 Author Share Posted October 14, 2006 Well, at the end of the day, it was the battery. Now I want to find out what would make a brand new battery go dead in 8 hours. But it runs! Quote Link to comment Share on other sites More sharing options...
anthonyiez Posted October 15, 2006 Share Posted October 15, 2006 wow, you didn't check the battery 1st. Quote Link to comment Share on other sites More sharing options...
