JDOwen2 Posted August 13, 2003 Posted August 13, 2003 What offset wheels are you guys using? Could I use the 17 inchers from an IS300? Or 18 inchers off SC430? Also, who has a decent price on waterpump and timing belt? Thanks
JDOwen2 Posted August 14, 2003 Author Posted August 14, 2003 I have a 95 SC300. Calipers are from a 95 TT.
AWJ Posted August 14, 2003 Posted August 14, 2003 A +45 should clear. The only way to know for sure if you will clear without test fitting is to order a set of wheels for a Supra. You can use a tap measure to check clearance also.
