faster20 Posted October 9, 2006 Share Posted October 9, 2006 The dealer told me that I needed a new throttle position sensor. With the help of this site I decided to do the job myself. After purchasing the part from the dealer I installed the sensor. When I started the car the idle was racing up and down. I put the old sensor back in and it sounds fine. I called the dealer and the parts guy sent my call to the shop. I asked if the sensor needed to be calibrated or if there was a test to see if the sensor was bad. Of course he stated that I needed to bring the car in for them to check it out. My question is twofold. Does the sensor need to be calibrated and is there a check that can be done on the old and new sensor to see if they are bad. Thanks Quote Link to comment Share on other sites More sharing options...
rlin78 Posted October 11, 2006 Share Posted October 11, 2006 The dealer told me that I needed a new throttle position sensor. With the help of this site I decided to do the job myself. After purchasing the part from the dealer I installed the sensor. When I started the car the idle was racing up and down. I put the old sensor back in and it sounds fine. I called the dealer and the parts guy sent my call to the shop. I asked if the sensor needed to be calibrated or if there was a test to see if the sensor was bad. Of course he stated that I needed to bring the car in for them to check it out. My question is twofold. Does the sensor need to be calibrated and is there a check that can be done on the old and new sensor to see if they are bad. Thanks I would make sure the new TPS is the same as the old one. I put in a new TPS, never had any problems, there's no calibration at all. Hope it helps. Quote Link to comment Share on other sites More sharing options...
