es300ct Posted August 13, 2003 Share Posted August 13, 2003 Hi, I searched the forums to no avail. I had an ABS sensor replaced about 2 years ago when I had the struts done (they probably broke it in the process). Anyway, the ABS light is on. Are there sensors on all four wheels ? They're so easy to change just not sure which one is bad (assuming that it is a sensor problem). Someone suggested Autozone for a free scan but they told me that's only for check engine lights, not ABS. Any ideas on narrowing it down ? Thanks.. Bob Quote Link to comment Share on other sites More sharing options...
SKperformance Posted August 16, 2003 Share Posted August 16, 2003 does the light saty on or only occasionally it is probably a wheel hub with excessive play or the sensor is damaged wither way you need a new sensor as to change the hub requires a new one as it is impossoble to press the old one out an reuse it all 4 wheels have a sensor Quote Link to comment Share on other sites More sharing options...
