I have lost the heat and a/c in my 92 sc300. The activation/temp. control button doesn't activate the system. I have also lost the display where it shows which vents are active, but the green illuminating light in that sect. of console is still working. I checked th #2 fuse (10) on the inside box that would power that and it was fine. Anyone?
i dont quite get whats happening. could you elaborate a bit more?
My ac and heat is dead, no display, it just wont turn on at all. It's like whatever powers the whole system isn't working but I checked the fuse for the ac heat and it looks fine. what fuses power the ac heat controls ?
Thanks a lot
Tim
there is a climate control unit that is know to go out. im not sure if it causes the lcd to not show. as far as i remember it made my heat on max cold or super hot!
