CanadaCraig Posted September 15, 2006 Share Posted September 15, 2006 Hi Guys!! :) I hope you're OK. My dealer tells me that the front two coil springs are 'sagging'. [i asked them to check the suspension because the car doesn't 'sit' as even as it should] Is it OK to replace JUST the front coils or should I replace all 4 of them?! They also said the original struts are fine and don't recommend getting new ones. [My '93 LS has about 85,000 miles or so] What would you do?! Thanks, Craig!! :) Quote Link to comment Share on other sites More sharing options...
leximus Posted September 15, 2006 Share Posted September 15, 2006 I just converted my air bags on my 91 LS400 to standard/conventional struts and every mechanic I asked recommended that I change all of them at the same time. Good luck. Quote Link to comment Share on other sites More sharing options...
CanadaCraig Posted September 19, 2006 Author Share Posted September 19, 2006 Hi leximus!! :) Thanks for replying to my question. I think that if I do go ahead and replace any of the coil springs - I'll replace all four. At least then - they'll all be new. AND the entire suspension can be thoroughly examined. [And not just the front end] Craig!! :) Quote Link to comment Share on other sites More sharing options...
leximus Posted September 19, 2006 Share Posted September 19, 2006 Good luck. Let me know how things turn out. Quote Link to comment Share on other sites More sharing options...
robert_ashfield Posted September 19, 2006 Share Posted September 19, 2006 If you are getting the springs done I would recommend replacing the struts as well, despite what the dealers says. I replaced the struts on my Mk I with 180k on the clock and my current Mk IV which has done about 75k and it made a huge difference to both cars - much more controlled, less bounce, better high speed stability, better cornering. Springs and struts should make a huge difference. If your current struts are original then they will be worn - they are a consumable item and only have a limited life. Aparts from the obvious signs like leakage, there is no really reliable test to check them, age/mileage are probably the best indicators. IMHO replacing the struts are the number 1 improvement you can make to an LS - I fiddled with bushes and secondary suspension parts on my MkI and they all make minor improvements, but nothing made as big a difference as the struts. Quote Link to comment Share on other sites More sharing options...
OmarG Posted December 6, 2006 Share Posted December 6, 2006 My car is sagging on the driver side, about one inch lower than the other side. I don't want to spend too much since i don't have that much, what are my options? What should i replace? Are aftermarket products ok? Thanks Quote Link to comment Share on other sites More sharing options...
ROYT Posted December 7, 2006 Share Posted December 7, 2006 OMAR When my LS was down on one side it had a broken front spring. I replaced them both myself. The strut comes out easy with the spring still on, you can work in comfort in a vice [make some lead jaw liners] What you do need is some really strong spring compressors. ;) Quote Link to comment Share on other sites More sharing options...
