I have a 93 es300 and the check engine light came on last week. I have already tightened the gas cap hoping this would be it, but unfortunatley it was not. I stopped by AutoZone to get the computer read for free but they say they can only check 96 or later models. Lexus wants to charge me $85 for a diagnostic test. Does anyone know of any options I may have that are less expensive than the dealer? Please help....
try another store
you need an obd 1 code reader
most shops have them
of go to a small independent and tehy might read it for $20
the 97 and ups are obd 2
but the es started the obd 2 codes in there redesigned 94 engine
You can read it easily. Open the diagnostic box. Short E1 and TE1 (?) with key "on". Read the blinking of check engine light.
1st Number of blinking is 1st digit of code, 2nd number of blinking is 2nd digit of code.
Fixing is another problem
that is the other way to do it
it is much simpler as for not needing toold
but i am not sure if i would recommend an average user to start shorting pins to an ecu
incase tehy get the wrong ones
