1992 Es 300 Cluster
I was just curious as to how to remove the cluster from an 1992 ES 300. I know that in some models, all you have to do is pull hard near the dimmer (as its held by clips, not screws...) and out it goes. What im not so sure about is if its the same for an ES. any suggestion?
Unclip thw two plastic clips at the top of the cluster cowl. Remove the two screws. Pull cowl towards you. Ensure that the steering wheel is fulling extended and in its lowest height position. Unplug odometer jack (lhs) and dimmer switch jack (rhs). Slip out from behind steering wheel. Done !
