godfather18 Posted August 26, 2006 Posted August 26, 2006 Hey guys I just hit 90,000 miles and wanted to change my timing belt, water pump, drive belts, cam seals and crank seals. How much do you think I am looking at if I go to Toyota to have the work done. Also does Toyota give u loaners with such a big maintence job cause I work alot and need a car if they have to keep it for a couple of days.
mburnickas Posted August 26, 2006 Posted August 26, 2006 Hey guys I just hit 90,000 miles and wanted to change my timing belt, water pump, drive belts, cam seals and crank seals. How much do you think I am looking at if I go to Toyota to have the work done. Also does Toyota give u loaners with such a big maintence job cause I work alot and need a car if they have to keep it for a couple of days. Go down a few topics, there is one there already. Also in my area Loaners are a no-go unless you pay for it or under the warrenty. it should be done in 1-day. Mine was dropped off at 8 am and done by 3 pm.
camlex Posted August 26, 2006 Posted August 26, 2006 Hello, In Houston, TX they runs 299 for V6 timing belt+ 1/2 hour labor+H2O pump+ 3 seal($10 a peice) 299+35+124+30 =488 + Tax. ~$550. What about spark plug and wire and fuel filter? Hope that helps.
mburnickas Posted August 26, 2006 Posted August 26, 2006 Hello,In Houston, TX they runs 299 for V6 timing belt+ 1/2 hour labor+H2O pump+ 3 seal($10 a peice) 299+35+124+30 =488 + Tax. ~$550. What about spark plug and wire and fuel filter? Hope that helps. fuel filter is lifetime on Es300's. Also he would be lucky to find a TB and H20 pump for that price (w/out labor in the northeast form a L dealer. Spark plugs are like 45 minutes doing it yourself. Grab a case of beer or whatever and go to town and save the few hundred.
godfather18 Posted August 26, 2006 Author Posted August 26, 2006 Has anyone here actually had there timing belt done at Toyota in the Jersey area?
