Micah Posted August 19, 2006 Share Posted August 19, 2006 Hello, I'm having trouble getting the drivers door panel off my sc400. I've been having problems with the wiring and want to evaluate it beneath, but can't access it without it off. The door handle seems to be the only thing left holding it on. I removed all the screws (including the ones beneath the arm rest) and the quick snap holders removed easily. How do I get around the issue of the door handle? Quote Link to comment Share on other sites More sharing options...
Micah Posted August 19, 2006 Author Share Posted August 19, 2006 figured out. There is a cover behind the door handle that I didn't notice. there's a bolt behind that Quote Link to comment Share on other sites More sharing options...
metramm Posted May 14, 2007 Share Posted May 14, 2007 figured out. There is a cover behind the door handle that I didn't notice. there's a bolt behind that Hello, I just bought an SC 300 and I need to replace the passenger side window regulator. I'm having some difficulty removing the door panel to get to the regulator. I was wondering if you could possibly tell me the locations of the screws/clips that I need to remove in order to get the door panel off. If you have any pics also that would be extremely helpful. Thank you very much for your time this afternoon and I'm looking forward to hearing from you soon. metramm Quote Link to comment Share on other sites More sharing options...
option00002 Posted May 14, 2007 Share Posted May 14, 2007 FYI I believe there are a total of 8 screws. Quote Link to comment Share on other sites More sharing options...
SirSam Posted May 15, 2007 Share Posted May 15, 2007 This should help: http://www.lexls.com/tutorials/body/fdoorpanel.html The hardest is actually the regulator itself. Haven't find a tutorial on that one yet. Quote Link to comment Share on other sites More sharing options...
