Since Sirus is not an option from the factory, I've moved my existing radio and am using the magnetic antenna on the roof.
Are there issues with water or rust or any long term issues that can be caused by keeping this magnet in the same spot? I remove it and clean it when I wash the vehicle and so far it's been okay.
I can remember the old CB radio magnetic mounted antenna's and the damage they would do to the paint.
Just wondering..
thanks
Ron..
It should be fine as it has 4 little rubber feet. The easiest way to prevent any problem is to wax the area well. Also you can get a small clear bra piece and add it to the panel for added protection.
