Superfly Posted August 13, 2006 Share Posted August 13, 2006 I have a 2001 GS 300 and I want to upgrade my stock rims and tires. I want to put 20s on put i dont want to ride on a 30 series tire. I'm thinking 19s with a 40 series. Also im looking to do a staggered setup 245/40/19 up front and 275/40/19 out back. Can anyone tell me if this combo will work. And if so, what kind of an offset ill need for the front and back. Thanks Quote Link to comment Share on other sites More sharing options...
Lex01_430 Posted August 17, 2006 Share Posted August 17, 2006 i don't think you can get away with 40 series. i have 19's with 245/30/19 and 275/25/19. i can't remember the offset, just do a search and you should find that out. i believe it was +38... Quote Link to comment Share on other sites More sharing options...
master Posted August 18, 2006 Share Posted August 18, 2006 You can run "fat setup" this is called, 245/40/19 +38ET front and 275/35/19 +38ET offset all around front/rear and you are set FYI, wheel size 19x8.5 front and 19x9.5rear Happy hunting Quote Link to comment Share on other sites More sharing options...
Lex01_430 Posted August 25, 2006 Share Posted August 25, 2006 i actually have 245/35/19 and 275/30/19. this was recommended by tirerack. they had cheap tires... about 1k delivered and mounted. Quote Link to comment Share on other sites More sharing options...
Belle Mead Posted August 29, 2006 Share Posted August 29, 2006 Guys, I am new at this and recently got a 99' GS400 and would like to upgrade to a staggered set up with 18x8's in the front and 18x8.5's in the rear. I have stock wheels and tires and would like to get better handling with a fairly decent ride. Will this set up get me what I want? Also, is there an offset required? Thanks Quote Link to comment Share on other sites More sharing options...
