Micah Posted August 10, 2006 Share Posted August 10, 2006 Has anyone ever experienced this problem? two scenarios: 1. Key in ignition: Open drivers door and the overhead light goes out and doors try to unlock twice. 2. Key out of ignition: Open drivers door and the overhead light goes out. In both cases the overhead light dims away as if I'm closing the door, but the door light on the dash stays on but dimms a little after the lights go out and the light on the door stays on. When I first open the door (just crack it open) all the lights work normally, but once I swing it all the way open, this happens. I'm sure there is a wire grounding out somewhere, but where should I start looking? It doesn't seem to be blowing any fuses. I did notice that the rubber grommet that covers the wires that goes from the drives door to the car's body is broken and I can see the wires If I pull it back. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted August 10, 2006 Share Posted August 10, 2006 You have found a problem so you know where to start. Quote Link to comment Share on other sites More sharing options...
