I don't think theres an O2 sensor on the intake.
You have a mass air flow sensor just after the filter. There's also an air temperture sensor near that.
What sort of chip do you have?
Sup there Vulcan! I was just reading through this forum and I want to ask you where I can get the chip or where I can order them. I'll appreciate the info. Thanks.....
  • 9 months later...
that chip/module is crap z1 module right?
it wires in to the air intake temp sensor which is part of th emass air flow meter of the is300, see my earlier post, it will only cause a check engine lamp, it does trick the ecu into thinking the incoming air is about 40-50% cooler than it is but causes cel, verified this temp drop using snap-on vantage scanner being that I work at a nissan dealership, highly recommend send it back. it is garbage
