juno_reaction Posted July 31, 2006 Share Posted July 31, 2006 ok, so i order new needles or cluster...and its basically a do-it-yourself job. where do i learn to put it in or together? im like.. a motorcycle person so like i really dont know anything about cars exepct how to run them. any tips? also, i was wondering if the new needles come with instructions on how to put them together.... THANK YOU IN ADVANCE. Quote Link to comment Share on other sites More sharing options...
steviej Posted July 31, 2006 Share Posted July 31, 2006 I thought with Lextech, you take out your panel and send it to them. I thought they installed the needles. You just go dash panel-less for a week or so. steviej. Quote Link to comment Share on other sites More sharing options...
juno_reaction Posted August 1, 2006 Author Share Posted August 1, 2006 Oh...well, i didnt know that. or anything when it comes to that matter. ok well, i dont even really know how to take the pannel out and even if i could take it then what would i do when it comes to wanting to change the panel from like... stock to an after-market kind? Quote Link to comment Share on other sites More sharing options...
svarog Posted August 1, 2006 Share Posted August 1, 2006 To go aftermarket panel probably have to reverse engineer the protocol lexus uses to send speed and all that, so basically you can't. Panel is pretty easy to take off if you just look at it. From inside on top here is plastics covers that cover screws, pop them off and use motorcycle !Removed! skills to unscrew them! I did it, was pretty easy. Needles probably would be harder to do but maybe once you look at it you can figure it out. There is also a pdf floating around that shows how to install a infrared black light thing and paint the needles fluorescent, you can find that and it has great instructions on taking panel off. I can also send if I find it in my email! Good luck. Quote Link to comment Share on other sites More sharing options...
juno_reaction Posted August 3, 2006 Author Share Posted August 3, 2006 ok, lets forget after-market things nad back to lextech.org. do i send the cluster in or can i buy a new cluster from them and install it myself? and if you say its not that hard then i shouldt have any problems correct? Quote Link to comment Share on other sites More sharing options...
svarog Posted August 3, 2006 Share Posted August 3, 2006 You send the cluster in! Car runs fine without it, just keep enough gas. Then they send it back with all the new needles, don't send it to them though without contacting first. Buying new one you probably have to use ebay, and it won't be new, just new to you. Quote Link to comment Share on other sites More sharing options...
