mferg Posted July 18, 2006 Share Posted July 18, 2006 I own a 2001 IS300. My check engine light came on yesterday and reading the codes revealed the following: P0440 (EVAP Emission Control System Malfunction) P0441 (EVAP Emission Control System Purge Flow Fault) P0446 (EVAP Emission Control System Vent Circuit Malfunction) Does anyone have any advice/thoughts on what this could be? The car runs fine, not noticeable issues/changes since the light came on. Thanks for any suggestions Mark Quote Link to comment Share on other sites More sharing options...
Cherokee_Outlaw Posted July 18, 2006 Share Posted July 18, 2006 I own a 2001 IS300. My check engine light came on yesterday and reading the codes revealed the following: P0440 (EVAP Emission Control System Malfunction) P0441 (EVAP Emission Control System Purge Flow Fault) P0446 (EVAP Emission Control System Vent Circuit Malfunction) Does anyone have any advice/thoughts on what this could be? The car runs fine, not noticeable issues/changes since the light came on. Thanks for any suggestions Mark I'm not a mechanic... nor did I stay at a Holiday Inn Express last night... But I do have a thought... the EVAP is gas vapors... and the computer detects a leak somewhere... Might check out your gas cap... if its busted or loose... it could allow vapors to leak... Quote Link to comment Share on other sites More sharing options...
SKperformance Posted July 18, 2006 Share Posted July 18, 2006 agreed but i did stay in a holiday inn express last year at Lex fest so that would make me an expert,i think Quote Link to comment Share on other sites More sharing options...
Heltah Posted July 31, 2006 Share Posted July 31, 2006 Here ya go http://www.obd-codes.com/forums/570-obd-co...0440-p0441.html same exact codes you have heres more info on P0440, the other two didnt have additional information http://www.obd-codes.com/trouble_codes/gen...malfunction.php http://www.obd-codes.com/trouble_codes/ Quote Link to comment Share on other sites More sharing options...
