truplaya22688 Posted July 17, 2006 Share Posted July 17, 2006 ok, first off if this is an old topic I am sorry as i tried searching and found similar problems however they werent the problem that i have, also i tried to use thier fixes and nothing happend. I was driving my 96 ES300 and when i pulled into my driveway my radio just cut out. Shut off the car and started it back up and the entire deck had no power to it. No radio, CD or tape. Also the back lights were not lighting either. Went to check the CD changer in the trunk and no power to that either, wont eject magazine. So I am currently not getting any power to the radio deck, the cd and obviously the antenna. Checked the 2 fuses for the radio and they were fine, the one under the steering and the one in the engine bay. I have no idea what to do. Any advise would help. I also just put it up for sale and now this! I am thinking its the wires, but I really dont know and I dont want to start taking things apart for no reason. Thank You. Quote Link to comment Share on other sites More sharing options...
steviej Posted July 18, 2006 Share Posted July 18, 2006 I would go back and check all the fuses. My 02 has three fuses inside alone that contribute to the radio. Since a component other than the audio is possibly involved, I would check all fuses. steviej Quote Link to comment Share on other sites More sharing options...
truplaya22688 Posted July 18, 2006 Author Share Posted July 18, 2006 I would go back and check all the fuses. My 02 has three fuses inside alone that contribute to the radio. Since a component other than the audio is possibly involved, I would check all fuses. steviej Question: Is the CD changer's power supplied through the stereo deck? Or does power go directly to the Changer? Thanks. P.S. I rechecked all fuses and relays and found nothing. I am going to try a new head unit and hope for the best. Quote Link to comment Share on other sites More sharing options...
godfather18 Posted October 5, 2006 Share Posted October 5, 2006 Dude I am having the same problem right now and dont know what it is, all fuses are fine. They are located right under the volume knob next to the changer and one under the hood next to the engine right? Quote Link to comment Share on other sites More sharing options...
sovietlexus Posted October 6, 2006 Share Posted October 6, 2006 in my 93 es the same thing happened.....what i did was get another power source and connect it to the power in the back of my radio....apparently the fuse(that i can't find) that blew is the same fuse for the amp too.....so either try to find the correct fuse or jump a wire from the fuse box to the radio Quote Link to comment Share on other sites More sharing options...
truplaya22688 Posted November 22, 2006 Author Share Posted November 22, 2006 Replaced head unit with another, works perfect now. Quote Link to comment Share on other sites More sharing options...
