jerryrigginson Posted July 5, 2006 Posted July 5, 2006 I was wondering if anyone else on here had a problem with the connection in the maf on their sc. The connector going to the airflow sensor is really loose and if you move it it makes the car idle up and down. I called the dealer they said 1000 dollars for a new maf which sucks. Is there an easy fix for this problem? My engine light comes on also.
jerryrigginson Posted July 5, 2006 Author Posted July 5, 2006 I was wondering if anyone else on here had a problem with the connection in the maf on their sc. The connector going to the airflow sensor is really loose and if you move it it makes the car idle up and down. I called the dealer they said 1000 dollars for a new maf which sucks. Is there an easy fix for this problem? My engine light comes on also. Does anyone know if the ls400 or any other cars use the same mass airflow sensor. My junk yards have no sc400s.
