chajones Posted June 26, 2006 Share Posted June 26, 2006 I has been raining a lot here lately, and while driving my wife's 2000 ES300 the AC light in the HVAC controls would start blinking after going through large puddles. The AC compressor apparently would stop as well, as the air through the vents became noticeably more humid. I could push the AC button and the light would go off, then push the auto button and everything would go back to normal. What is cauising this, and do I have a problem? Thanks. Quote Link to comment Share on other sites More sharing options...
mburnickas Posted June 26, 2006 Share Posted June 26, 2006 Belt slipping on pully? Quote Link to comment Share on other sites More sharing options...
amf1932 Posted June 26, 2006 Share Posted June 26, 2006 Possibly slightly low refrigerant level. Quote Link to comment Share on other sites More sharing options...
lexusk8 Posted June 26, 2006 Share Posted June 26, 2006 The link below tells you how to diagnose problems in your A/C system. Although the link uses the LS400 as an example, the procedure works for the ES (I know this because I tried it out in my '01 ES). http://www.lexls.com/tutorials/air/accodes.html Quote Link to comment Share on other sites More sharing options...
steviej Posted June 27, 2006 Share Posted June 27, 2006 the belt was slipping on the pulley when it got wet. This happened to me recently. Been raining here since middle of May. Turns out the left side of my underside splash guard had lost two pushpins and was hanging a bit. Water easily got up on the pulley in puddles. Fixed the splash guard and severely decrease the amount of water that can get up there. Several rain storms since and no flashing light. Now, if it happens when the car is totally dry and you don't get wet from a puddle, then start looking into it further. When was the last time the belt was replace or tightened? steviej Quote Link to comment Share on other sites More sharing options...
chajones Posted June 27, 2006 Author Share Posted June 27, 2006 the belt was slipping on the pulley when it got wet. This happened to me recently. Been raining here since middle of May. Turns out the left side of my underside splash guard had lost two pushpins and was hanging a bit. Water easily got up on the pulley in puddles. Fixed the splash guard and severely decrease the amount of water that can get up there. Several rain storms since and no flashing light. Now, if it happens when the car is totally dry and you don't get wet from a puddle, then start looking into it further. When was the last time the belt was replace or tightened? steviej Thanks for the advice. I don't know when the belt was last serviced. I bought the car last fall with about 45,000 miles on it from a dealer as a CPO. I have only had it serviced at the dealer, including the 60,000 miles service. My guess is that at the 90,000 mile serve the belts will be replaced. I suspect you're correct though, becasue it only happened during torrential rains going through rather deep puddles, and has not happened before or since. Thanks again. Quote Link to comment Share on other sites More sharing options...
