Regreasing Pulleys
I cant believe somebody else beside myself does that. I use Polymolybodium/disulfide high temp bearing grease. Some pulleys can not be greased as the seal on the bearing is not removeable. If it has a plastic grease seal I pop it out with a sharp scribe and then apply grease with my finders rotating the bearing to quiet it down. If it does not roll smoothly, it is shot and must be replaced. After greasing I push the grease seal back into the bearing carefully. Good luck.
