I Have Some Vibrations.....
They feel as if they are coming from the frone end of the car, though I never feel them through the steering wheel. Are there any common causes for this on the ES? My tires are balanced, and my alignment seems to be in check.
Can you be more specific in describing the problem, such as the speeds that it's most noticed etc? How many miles on the car? The more detailed you are, the better we can assist. ;) I assume your air pressures are correct in your tires?
:cheers:
:cheers:
About 79000 miles. It will happen above 50 mph normally, I can't remember if it stops at a certain speed above that though. Tires are all inflated properly. I noticed today that the dust boots on all four struts are shredded into pieces... maybe those are going now :whistles:
:cheers:
My car starts to shake at higher speeds i dont know if thats whats going on with your car. My rotors need replacing
  • 2 months later...
