BjCaleb Posted June 15, 2006 Share Posted June 15, 2006 Hey Ladies and Gents, My 98 GS300 is ticking and my mechanic told me it is the Engine Valve where the noise is coming from. You guys ever had the same problem? And if so, how much was it to fix the problem? Thanks Quote Link to comment Share on other sites More sharing options...
hiholex Posted June 15, 2006 Share Posted June 15, 2006 Hey Ladies and Gents, My 98 GS300 is ticking and my mechanic told me it is the Engine Valve where the noise is coming from. You guys ever had the same problem? And if so, how much was it to fix the problem? Thanks The ticking sound could be from the direct fuel injectors at each cylinder. At idle in park the noise may be heard, but as you drive you should not be able to hear it. If you still hear the ticking as you drive and it gets louder as the rpm goes higher, then it could be the valves or something else. Quote Link to comment Share on other sites More sharing options...
